johnny Posted July 8, 2015 Share Posted July 8, 2015 I have a home I'm working on - modern design - and I'm wanting to use CA. Is there a reason why I couldn't make a wall that was glass and then manually place the frame pieces in where i want/need support etc? I see this as a superior way than trying to mess with windows. Link to comment Share on other sites More sharing options...
ShaneK Posted July 8, 2015 Share Posted July 8, 2015 Make a large glass window and use poly solids as window dividers. I do this for commercial glass or store fronts on occasion. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 8, 2015 Share Posted July 8, 2015 Give the Trial Version a Run and try things for yourself , only limitation is you can't save your Work , so don't close CA if working on something special for a day or two. Link to comment Share on other sites More sharing options...
OldCKD Posted July 8, 2015 Share Posted July 8, 2015 Couldn't you use custom muntins to do what you want? That way you would be able replicate each section however many times you needed to. The only thing I'm not sure of is whether you can control the width of the dividers (muntins) using that method. Link to comment Share on other sites More sharing options...
ShaneK Posted July 8, 2015 Share Posted July 8, 2015 Custom glass Link to comment Share on other sites More sharing options...
