Lees Working.planOk so I'm using x7, doing a remodel. The existing plan has been established. I'm wanting the center area (which was a courtyard) to become heated space, with a 20' ceiling, with high windows in the protruding area. I want to see the walls when I build the second story, and maintain temporarily all the roof planes on the existing plan in order to work on the new roof. When I add 2nd floor, and edit the walls to the shape I am looking for, the walls do not build in 3d view, just the floor and ceiling. If I rebuild the roof, I don't know how to maintain the planes that were auto built before, as they are unedited. However, rebuilding the roof seems to be the only way to get the walls to extend up to the second floor. I must be missing something. Attaching plan...
If you can't figure this out, let me know and I'll help you online. I assume you're doing a "save-as" for the proposed plan.
You have to pull the roof eaves back, then build a second floor.
You do realize that when you do the proposed plan, you need to move those existing roof planes back in order to generate the new walls to where they can be seen above the existing roof planes.
If I am understanding you I think all you need to do is select all the roof planes and then cut them, build 2nd floor from 1st and then paste hold position. Then transform replicate the roof planes to desired height.
Thanks for the tips. Could it be that simple? Moving the planes out of the way? I will see. Thanks again.
Basic rule: 9 times out of 10, a roof plane will always cut a wall off.
    27861
    mmebsc
    mmebsc
  • Similar Content
    • By ilastu
      I successfully imported the floor plan for a house from a dwg file, however I have not found a way to convert the roof drawing into 3D. Is there a way to do that? I am using the X11 version.
    • By hamedDesighn
      How to fix wall length Or lock the wall dimention so they don't change .
      i would be thankful if somebody help .
    • By SpeleoWorm
      I have created a number of different wall types to show proper dimensions (i.e. when one side of the wall is 5/8" Type X and the other side is 1/2" drywall) as well as to calculate the correct material counts and to show the proper information in the schedules.  Unfortunately doing that seems to have a down side...it changes the framing as if they were separate walls instead of the same wall with different materials on them.  I have seen the following side effects (colors refer to screenshots below):
      (Green Arrow) In unfinished rooms such as an attic storage space which only has a subfloor but no drywall, the walls get pushed up into the rafters by what appears to be 3". (Red Arrows) The floor joists and top/bottom plates are cut in the middle when they should be continuous pieces of wood.  In addition, you can see that the walls which are produced are not boxed at the end...the top & bottom plates stick out at the end. (Purple Arrow) Parts of the gable wall are not created.  In this case you could argue that it is not needed, but if a builder makes a wall he is not going to leave a hole in it. (Blue Arrows) An extra stud is added to a room that has no drywall, and therefore doesn't need nailer studs.  In addition, it looks like the other stud needed as a nailer for the finished room in the middle is missing from the plan view of the framing (see 2nd screenshot).
      Am I doing this all wrong (creating separate wall types), or is there a way to use them and fix (any of) the issues I mentioned?
      Thanks in advance for any help!
      PS - I am a little surprised that the wall finish is not part of the room settings (like the floor & ceiling already are)...that would allow you to have continuous walls and still have different materials in each room (i.e. greenboard in the bath, 5/8" type X in a garage, unfinished in an attic, etc.
      Example of Wall Issue.plan
    • By TCDLLC
      Hi, I am a Revit user converting to Chief.
      When working with angled walls in Chief, I have not been able to lock a wall from moving when changing dimensions on connecting walls.
      I am familiar with how to use the directional tools to move an end of an object to adjust its dimensions.
      When angled walls are off-angle, I can waste significant time adjusting the lengths of the angled walls and still not achieve the dimensions I need for all connecting walls.
      The use case scenario is when I am drafting a plan using dimensions provided to me to create the build.
      Of course, if I was creating a plan from scratch, I could probably avoid this situation.
      Any suggestions?
    • By kylejmarsh
      When I multiple select roof planes, I am given the option to change their baseline height or their pitch, and nothing else. So I have to go into each roof plane and set it's fascia height individually - which stinks, partly because of CA's dialogue-box heavy interface. If I have to open up a dang dialog box, can't I at least have the option to override all and set the fascia and pitch or ridge and pitch, etc. for all the roof planes selected?
      This is a larger part of the underlying issue, which is that CA needs to invest in a GUI redesign because this one is so clunky and cumbersome. Please Chief, please. Please.
