basilbabaa Posted May 17, 2015 Share Posted May 17, 2015 Been working with roof design for hours. All of a sudden, i am getting this ghosting of what appears to be the roof decking material? Any ideas? Only appears in Perspective full overviews, NOT in Full Camera angle shots. Thanks. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 17, 2015 Share Posted May 17, 2015 check this KB , it's known as Z-fighting, search that on the forum and you will get a number of hits check the section on accommodating large terrains , set to 300 has helped me before I have seen it mentioned to make the Roofing material thicker as well , or changing the OSB/Ply to the same colour may help. http://www.chiefarchitect.com/support/article/KB-00107/0/Troubleshooting-Why-Materials-Appear-to-Flicker-When-a-Camera-View-is-Rotated.html Link to comment Share on other sites More sharing options...
HumbleChief Posted May 17, 2015 Share Posted May 17, 2015 I have seen it mentioned to make the Roofing material thicker That should do the trick. Link to comment Share on other sites More sharing options...
Solution basilbabaa Posted May 17, 2015 Author Solution Share Posted May 17, 2015 Thanks Guys! Never had that before... And just started all of a sudden. Maybe I accidentally changed a default somewhere. But that got it! Link to comment Share on other sites More sharing options...
