Askod1 Posted May 11, 2015 Share Posted May 11, 2015 I recently started working with Chief X7 for MAC OS. I am working on my first project which is a restoration project of an old victorian house. I am having some difficulty in some areas of the project. I will simply try to ask 1 question at a time and hope I don't become to much of a PIA. Pertaining to exterior walls. I cannot figure out how to get the wall ends of the exterior walls to display with gyp board as oppose to the exterior finish protruding through where the exterior wall and interior walls meet, as shown in the screen shot attached. Any and all help would be appreciated. Thank you. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted May 11, 2015 Share Posted May 11, 2015 Looks like maybe your walls are not joined properly. Something weird there. You may need to either post a pic of the plan view and/or post the plan. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 11, 2015 Share Posted May 11, 2015 Use the "Edit wall intersection "tool to move the brick back where it should be. 1 Link to comment Share on other sites More sharing options...
Solution TheKitchenAbode Posted May 11, 2015 Solution Share Posted May 11, 2015 There appears to be a slight jog (offset) in the wall to the left of the exposed brick versus the right side, shows at the baseboard. Maybe this is required or as Dennis suggests the wall sections are not connecting properly. Also, is the main interior wall with the door openings an actual interior wall type or did you just extend the exterior wall through and change the cladding finish. For myself I usually draw all the exterior walls first and then go in and attach/position the interior walls. Graham Link to comment Share on other sites More sharing options...
Askod1 Posted May 11, 2015 Author Share Posted May 11, 2015 OK, as you all pointed out my exterior wall was extended into the interior and i was able to remedy that quite easily after it was pointed out. (though feeling a bit embarrassed about such a rookie mistake.) Thank you. I'm sure I will be post more questions as i proceed with the project. This is not exactly the simplest plan for me to have to start with as im certain that the finished attic and roof are going to give me fits. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted May 11, 2015 Share Posted May 11, 2015 Use the "Edit wall intersection "tool to move the brick back where it should be. Too many tools to keep track of!! Good one Perry. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted May 11, 2015 Share Posted May 11, 2015 OK, as you all pointed out my exterior wall was extended into the interior and i was able to remedy that quite easily after it was pointed out. (though feeling a bit embarrassed about such a rookie mistake.) Thank you. I'm sure I will be post more questions as i proceed with the project. This is not exactly the simplest plan for me to have to start with as im certain that the finished attic and roof are going to give me fits. Appreciate the "Vote" in confidence however this should most likely go to Perry and/or Dennis. Pleased your problem was resolved, Graham Link to comment Share on other sites More sharing options...
