yusuf-333 Posted May 29, 2015 Share Posted May 29, 2015 ..........I would get two layers of studs..... Another solution but not perfect..... Scott were are you? Here is the framing also. Is this what you did? OK no not probably. Are you going to post hope you got it. Waiting for you 2 minutes, Then I am going to post it. Link to comment Share on other sites More sharing options...
dshall Posted May 29, 2015 Author Share Posted May 29, 2015 I see what you did Yusuf, I can do that. I will exaggerate the issue. Buick a 12" thick wall, put a window with a 3" frame and inset the frame 8". Do you now see the drywall on the exterior that Brian and I see? Link to comment Share on other sites More sharing options...
dshall Posted May 29, 2015 Author Share Posted May 29, 2015 ..........I would get two layers of studs..... Another solution but not perfect..... Scott were are you? Here is the framing also. Is this what you did? OK no not probably. Are you going to post hope you got it. Waiting for you 2 minutes, Then I am going to post it. And no, I do not know exactly what you did in that model. I guess that is why if is helpful to post the plan so we don't spend an hour going back and forth refuting each other's solution. Link to comment Share on other sites More sharing options...
yusuf-333 Posted May 29, 2015 Share Posted May 29, 2015 I see what you did Yusuf, I can do that. I will exaggerate the issue. Buick a 12" thick wall, put a window with a 3" frame and inset the frame 8". Do you now see the drywall on the exterior that Brian and I see? Yes definitely you will see it. You and Brian missed the poisonous setting! I found it.... Saaaaa Link to comment Share on other sites More sharing options...
yusuf-333 Posted May 29, 2015 Share Posted May 29, 2015 .........sh! Link to comment Share on other sites More sharing options...
yusuf-333 Posted May 29, 2015 Share Posted May 29, 2015 Scott's buck window ultimate plan buck scott.plan Link to comment Share on other sites More sharing options...
dshall Posted May 29, 2015 Author Share Posted May 29, 2015 Thanks for the model Yusuf. Here is a pic if I have a 12" wall and the window is inset. YUSUF buck scott YUSUF 2.plan Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 29, 2015 Share Posted May 29, 2015 Scott,Check the attached Plan.The Wall with the Window in it is "No Room Definition".It has just a 1/8" Thick Stucco Exterior Layer.I trimmed the top down to the Interior Casing.You could trim the bottom up but then you would need to adjust the Window Height so I just left the bottom.The Pass-Thru in the thicker wall has a Frame (Stucco Material)The Pass thru is 6" wider and taller than the Window and the top is 3" higher.Once the thinner wall is moved into place, That Wall and the Pass-Thru can be selected together and moved or copied any way you want. :D :D B) Buck Framed Windows.zip Link to comment Share on other sites More sharing options...
dshall Posted May 29, 2015 Author Share Posted May 29, 2015 I think somebody came up with the no room def wall idea about 358 posts ago. It is a possibility. The issue with that is if plate heights change or room floor heights or ....... blah blah blah, there are issues. I ruled that out a while back. Link to comment Share on other sites More sharing options...
dshall Posted May 29, 2015 Author Share Posted May 29, 2015 It was Dennis, see post 18. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 29, 2015 Share Posted May 29, 2015 Scott, It's not quite the same. I left the No Room Definition Wall at the Floor. That's kind of a mix between Perry's and Dennis's solution. Changing the Structure doesn't get messed up this way. That wall doesn't have to be trimmed at the top but I just thought it left less vector clean-up for Elevations. It also Frames nicely I think you should at least experiment with it a bit ..... Link to comment Share on other sites More sharing options...
yusuf-333 Posted May 29, 2015 Share Posted May 29, 2015 Thanks for the model Yusuf. Here is a pic if I have a 12" wall and the window is inset.Doug gone it! But that case may need additional enterior casing(hole casing)with stuco to cover the dry wall, but very small thicknes as i explained in my previous post.Thanks for all.... Link to comment Share on other sites More sharing options...
dshall Posted May 29, 2015 Author Share Posted May 29, 2015 Doug gone it! But that case may need additional enterior casing(hole casing)with stuco to cover the dry wall, but very small thicknes as i explained in my previous post. Thanks for all.... thank you Yusuf Link to comment Share on other sites More sharing options...
yusuf-333 Posted May 29, 2015 Share Posted May 29, 2015 thank you Yusuf You welcome, thanks Scott. Link to comment Share on other sites More sharing options...
