X7 Wall Labels - Tip
Joe_Carrick
I have my Wall Types named so I can easily see what the construction is.  I have defined the default Label for Exterior Walls and Interior Walls as:
Wall-%floor_number%.%wall_id%  --  %wall_type%
so that when I draw walls the label shows me what I'm using.
I also have most of my Wall Types saved in folders in my Library so I can just select what I want to use at any time.
This takes a little bit of setup but it works for me.  Note:  The Label is the name that will be given to the Wall Detail in the Project Browser.  That's a nice additional feature.
