Dominic900 Posted August 25 Share Posted August 25 There was an X18 update released today. A vast improvement in library load up speed for both material library and library browser. Your speed may vary but my library speed took less than a second to load for both libraries mentioned. Thank you Chief Architect! Please see new update notes for more that was improved. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 25 Share Posted August 25 I got this when I tried to install. I'm pretty sure it's happened before but I don't remember what I had to do to fix it Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 25 Share Posted August 25 Got it fixed. One of the Windows Security settings. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted August 26 Share Posted August 26 The update notes are here: https://cloud.chiefarchitect.com/1/pdf/documentation/chief-architect-x18-update-notes.pdf It looks like they just fixed a few things they thought were important. I heard that they are still working on other fixes that will go into 28.2 but I don't know when that is coming out. Link to comment Share on other sites More sharing options...
KCW_Build Posted August 27 Share Posted August 27 On 8/25/2026 at 5:15 PM, Joe_Carrick said: Got it fixed. One of the Windows Security settings. I am experiencing the same issue as well. What settings did you change to restore the program? Thanks - Andrew Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 27 Share Posted August 27 1 hour ago, KCW_Build said: I am experiencing the same issue as well. What settings did you change to restore the program? Thanks - Andrew Don't remember exactly. Call tech support - they can walk you thru it. 1 Link to comment Share on other sites More sharing options...
