TheKitchenAbode
Processor Core Usage In Chief ?
Larry,
You're the man! The OS was the limiting Factor. Now that I have "Added the PRO features"to my existing installation, I can see both CPU's and Chief see's 24 threads. Whoya!
Suggest using the Windows task manager. It will display a graph for each core and show % usage. May be better indicator than core temp.
Graham
For those of you who care. the E5.2620 v3's are running 33C at idle and 45c and full X7 render mode. The attached was a sample test render.
Perhaps Doug could set us up with a benchmark file with preset Camera and layer settings for to compare and contrast.
Attached:
HIGH QUALITY - INDOOR
1781 x 805 @ 300 DPI
nearly 16 passes in 0:16:55
Speccy will give much more detail on the CPU core functions than either Task Manager or Resource Monitor.  Speccy is an invaluable tool to check operational specification vs. expected/published specification on newly built systems.
Meanwhile, MS Resource Monitor allows "live" service, handle, and module granularity of processes using the CPU(s).
jon
Scott, try stressing the system.  Add > 20 various light types (point, spot, directional, UDL, fixture, sunlight) and ray trace an image at least 12"x12" @ 300dpi.  Both interior and exterior cameras.  If you're still getting approx. 1min per pass, then I would say the system is a rock star.
jon
Great idea Jon! I'll do it and post the layer parameters too. I heard somewhere to turn off everything anywhere that is not involved in the field of view to make faster render times.
True, but as a new system stress test, the above is what I use with ray trace.  A variety of materials and model types doesn't hurt either. (3D trees are always good as poly hogs)
jon
is that really realistic for plans? 3600 x 3600 at 300 DPI
Plans, no.  Marketing materials output, yes.
jon
Hi Scott - is this correct, on your first run you reported 16 passes in about 16 minutes. Now you are reporting 10 passes in 1:45. That's a very significant reduction in Raytrace time. Did you make other changes?
Graham
Graham,
Have you tried rendering an image of that size and resolution? I actually think it was pretty good given the parameters. Rarely, if ever, would I render something that large, but if need be I could live with those numbers.
Jon, what are your numbers?
Graham
Graham I believe Scott's time is 1:45:00. 1 hour 45 minutes 00 seconds but can't really be sure.
Scott, A couple questions for you. What coolers are you using, and if you don't mid telling what did you pay for your system.
Oh yeah what file are you using for the time you posted?
Graham,
Have tried rendering an image of that size and resolution? I actually think it was pretty good given the parameters. Rarely, if ever, would I render something that large, but if need be I could live with those numbers.
Scott,
I think the last Raytrace time is really good, that equates to 10 sec per pass. Was just wondering how you got such a significant reduction compared to your first posted result that was around 1 minute per pass.
That is correct one hour and fortyfive minutes.
Noctua NU14S are my CPU coolers
Any chance that you could post this plan so we could all give it a try?
Graham
To level the playing field, and provide real-world hardware comparisons...
  1. Download the Riverstone plan from CA
  2. Use all default settings for that plan
  3. Position the camera in the masterbathroom at X:507, Y:425, X:0
  4. Leave all Light as the default (168 on + Sun)
  5. Select Final View with Shadows
  6. Select Indoor- High Quality Raytrace
  7. Launch Assistant
  8. Retain Aspect Ratio
  9. Screen size 1781 x 805
  10. 300 DPI
  11. Lots of Focal Blur
  12. No Caustics
  13. Run for no more than 1 hour
Post your Screenshot with Timecode at the bottom of the Screen.
Cheers!
  7. Launch Assistant
  10. 300 DPI
  12. No Caustics
Cheers!
Scott there is no 'Indoor High Quality' Setting per se. There is one that comes stock with Chief but has been altered a lot in my usage. However within that setting are 'settings' that we could duplicate but we would need a screen shot of the settings your are using.
What setting is 'lots of focal blur'?
Also wouldn't running the RT for "no more than 1 hour" just give us an RT that ran for the same amount of time?
How about a number of passes instead? Then we could compare times instead of all having the same time?
Fear not ye mere mortals for we are not to be defeated today.
With just a few lighting tweaks.
10 passes 10:38 minutes/sec, that's about 1 minute per pass.
Intel 2 Quad Q6600 2.4 GHz 4GB ram
For comparison the original without lighting tweaks took 54 minutes to make just one pass.
Graham
Graham,
What tweaks did you apply? The goal here is to determine the optimum settings in both CA and our respective Hardware to obtain maximum result. Post a screen capture before you stop the render so we can see the TIME, PASSES and SIZE from the bottom of the screen.
Beautiful image!!
Thanks,
    27831
    Talal1975
    Talal1975
  • Similar Content
    • By DesignByChad
      Is anyone using MS Surface machine with x12 ? Do you get good speed and graphics rendering?
      Thanks,
      Chad
    • By carowe
      I just bought a new desktop and two 27” monitors in December and last week signed a contract on a job out of state that will require quite a bit of travel.  I am going to have to get a new laptop but really don’t want to spend a fortune at this point and don’t want to have to buy another license.  Most of my work will be done in my office, but on my trips out there will need to access my CA files, and perhaps work on them. What would be the minimum requirements I would need in order to access my main computer and let it do the heavy lifting on CA?  I use X11 Interiors and will primarily be working on kitchen and bathroom designs for the architect.
    • By PvdPol
      Dear all,
      I'm new to the forums and i've tried to find my way in the already existing topics, such as
      - https://www.chiefarchitect.com/products/sysreq.html
      - https://chieftalk.chiefarchitect.com/topic/21934-hardware-recommendations/?tab=comments#comment-179153
      I could not find an answer yet, hopefully some of you can help me out.
      I am currently struggling with Chief Architect Premier, ray traces are really slow at 1080P (1 pass takes like 15-30 min)
      Also working for in PBR is making my system really really slow and it is getting frustrating.
      My model is not complex and I think I need an hardware upgrade.
      Current machine (Notebook - April 2014)
      X•BOOK 15CL56 NVIDIA GTX770m 3GB, Full HD (+/- 20000 3DMARK) Intel® CoreTM i7-4710MQ (6M Cache, up to 3.50 GHz) - 47Watt (Quadcore) 16GB DDR3L (1600MHz)
        New system specifications (not bought yet)
      AMD Ryzen 7 3700X Boxed MSI X470 Gaming Plus Max Crucial Ballistix Sport LT BLS2K16G4D30AESB  (32GB Ram) Intel 660p 1TB Solidstate drive Graphic card? Nvidia? Any Advice?
      I think the 32 GB of memory is already an overkill, not sure if this is needed.
      But I'm mostly wondering regarding the choice of CPU and Graphics card
      Is this a good setup? What kind of performance improvements can I expect? What would be your advice?
      Thank you!
      Regards,
      Peter
    • By winglakedesign
      Hello everyone,
      I am about to purchase a new MacBook Pro.  Mine current MacBook Pro is  2015, Intel Core i5, 2.9 GHz, 8 GB MHz, Intel Iris Graphcs 6100 1536 MB.  Whatever all that means....I get the swirling rainbow often because I run Affinity Photo and Home Designer Architectural along with a few other things being open at the same time...mail, messages, etc.
      So - time to upgrade.  I don't know which is more important to help run programs quickly - Obviously - I would like the upgrades on all - but it's already so expensive so wondering if the combination of standard and some upgrade will be okay.  I have  design business and use Chief Architecture for floor plan and furniture layouts to present to clients.
      1) 2.6GHz 6‑core 8th‑generation Intel Core i7 processor, Turbo Boost up to 4.3GHz (standard)  vs
      2.9GHz 6‑core 8th‑generation Intel Core i9 processor, Turbo Boost up to 4.8GHz
      2) 16GB 2400MHz DDR4 (standards)  memory vs.
      32GB 2400MHz DDR4 memory
      3) Radeon Pro 560X with 4GB of GDDR5 memory (standard) vs
      Radeon Pro Vega 16 with 4GB of HBM2 memory vs
      Radeon Pro Vega 20 with 4GB of HBM2 memory
      I was originally thinking of doing the upgrade to the i9 intel processor - only but then someone mentioned upgrading the graphics card.
      I am sticking with Mac at this time because it's what I know.  Can anyone advise please?  Thank you so much!
    • By AnotherCADUser
      I've been getting into the rendering and video side of CA. I've been using a Mac with 12gb shared ram, which is ok, but you can see it's not great, esp the frame rate. I want to really get into it with clients so I'm going to get X10 and my son said it should be smooth as with this machine. What do you think?
      https://www.dell.com/en-au/shop/dell-laptops/new-inspiron-15-7000-gaming-laptop/spd/inspiron-15-7577-laptop/a511070au
