Build Wall Framing
Joe_cul
Are you automatically building the wall framing or are you manually building it?  It's pretty easy to just select a wall and say "build framing for selected object" to build it.  If it doesn't actually build any framing, then it is something wrong with your wall.  99% chance that you did something to the wall type when this is the case.  Most likely you don't have the main wall layer set to be framing*.  If it's not that, then you should probably post your plan.
*In Michael's picture above, note how the "framing" checkbox that is below the table is not checked.  You need to make sure that it is checked for the wall's "main layer".
Edited by DBCooper
