Oval Room
gls123
Is there a way to create an oval room? Creating a series of curved wall segments is not working for me because there a lot of windows needed in this oval room.
If not is there a way to control the limited distance from a door and window jamb to the end of a wall segment? Currently I can move a door/window no closer than about 3.5" to the end of a wall segment. If this can be changed to 0" perhaps the oval room can be created with curved segments.
Thanks.
you may  need to change the Plan defaults>Window>General>  minimum window separation setting too and perhaps some setting on the framing tab as well as there would usually be 2 studs + RO space either side of a window and door too.
As for drawing an Oval room , one of the Gurus may need to help with that :)
Forgive me, it's almost end of day Friday here. Why not just run for the Presidency, one comes with the job. Not sure of your location but if you decide this to be the easier route then just remember to make sure your birth records will be officially recognized. :)
Graham
