j2narchitecture Posted 6 hours ago Share Posted 6 hours ago Hello. How do I trim the bottom of the rafter so that it is cut square to the top of the steel beam or a 2x plate on top of the steel beam? Currently, the rafter is extending through the steel beam. I have the beam set as a Roof Beam. See area in Red circle. Thanks in advance! Link to comment Share on other sites More sharing options...
