mctabish Posted March 24, 2014 Share Posted March 24, 2014 I am running out of space on my C Drive. I need to move all CA files that I can to another drive. I want to move at least the following: libraries, textures, histories and plans as they take up a lot of space. How can I do this and still have CA recognize my libraries, textures, histories and plans that I currently have. Thanks! Bruce Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 24, 2014 Share Posted March 24, 2014 You can put them basically anyplace you want and use mklink to create a virtual link for Chief's default locations. This means that you still have the folders that chief expects, but those will be empty and will simply serve as a pointer to the actual folders where your files are located. Link to comment Share on other sites More sharing options...
mctabish Posted March 24, 2014 Author Share Posted March 24, 2014 Thanks! I had never heard about mklink! I will play with that tonight! Cheers, Bruce Link to comment Share on other sites More sharing options...
Kbird1 Posted March 25, 2014 Share Posted March 25, 2014 Some of the locations can be changed in Preferences>General>Folders a lot of stuff is stored in My Documents>CA Data Folder... so just set the location for the My Documents folder in the Folders Properties , I use an SSD for C:\ so locate all my "Libraries" on a Data drive, in the case of My Docs it is on D:\ you can also move all your Pics, music ,videos etc like this to free up space on C:\ ,when you hit apply , it will ask you if you want to move all the files to the new location , ok that and it is all done automatically. To get the Folder locations to show up in the properties DBX make sure you are in your USER folder>My Docs>RC>Properties>Location Tab ( RC= right click) M Link to comment Share on other sites More sharing options...
