Need to move where data is stored on HD for CA
mctabish
I am running out of space on my C Drive.
I need to move all CA files that I can to another drive.
I want to move at least the following: libraries, textures, histories and plans  as they take up a lot of space.
How can I do this and still have CA recognize my libraries, textures, histories and plans that I currently have.
Thanks!
Bruce
You can put them basically anyplace you want and use mklink to create a virtual link for Chief's default locations.  This means that you still have the folders that chief expects, but those will be empty and will simply serve as a pointer to the actual folders where your files are located.
Some of the locations can be changed in Preferences>General>Folders
a lot of stuff is stored in My Documents>CA Data Folder...  so just set the location for the My Documents folder in the Folders Properties , I use an SSD for C:\ so locate all my "Libraries" on a Data drive,
in the case of My Docs it is on D:\  you can also move all your Pics, music ,videos etc like this to free up space on C:\ ,when you hit apply , it will ask you if you want to move all the files to the new location , ok that and it is all done automatically.
To get the Folder locations to show up in the properties DBX make sure you are in your USER folder>My Docs>RC>Properties>Location Tab    ( RC= right click)
M
    32609
    organiccrack
    organiccrack
