Shed and Gable Roof Fascias - Alignment
Go to solution Solved by GeneDavis,
Hi.
Is there a way to automatically frame a shed and gable roof so that their fascias align? I want the gable and shed roof fascias to be clean and continuous.
Any help is appreciated.
Thank you kindly.
Examine both roofs in a section view to see which one is more readily raised or lowered, framing-wise.  Then open the one you choose as fixed-no-edit, copy its fascia height, close, open other roof for spec, lock its pitch, and past in that fascia height.  Done.  Just like you did way back in X12 and X13.  You will need to edit the intersections.  Reframe.
Any roof plane can be moved in 3D space.  In a 3D view with roof planes turned on, all framing off, select one or both of the laid-on wings.  Do a screencap pic of what you see, and post it here.
All four planes shown here have the same fascia height.
Edited by GeneDavis
Here are current screen shots.  All 4 fascias are set to same height.  On the 3D framing view, I was able to use the "join and lap ends" framing tool to get the fascias to join like I want them. It is not carrying over to the 3D full view, nor elevation drawings.  Attached is also a concept pic of my end goal.
Hi.  @GeneDavisMy goal is to. have the fascias of the gable and shed roof to be continuous - like the area in the red box.  Hope that makes sense.
@BenPalmer The joining roofs option would work, but for framing/construction purposes, I want to show the shed roof being framed over/on top of the gable roof.
  • Solution
Posted (edited)
Like this?  Edit the upper roof to pull back the section of overhang the lower roof lays on.  I pulled it back to the center of the wall so the wall rises as you want to see it.
Edited by GeneDavis
