DefinedDesign Posted May 20 Share Posted May 20 What is the fastest and most reliable way to identify the actual paint/material currently applied to a wall surface? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 20 Share Posted May 20 Put a 1/16" thick interior & exterior layer in the wall type. or specify a wall covering in the room. Then select the paint color from one of the paing catalogs as the material Link to comment Share on other sites More sharing options...
DefinedDesign Posted May 20 Author Share Posted May 20 9 hours ago, Joe_Carrick said: Put a 1/16" thick interior & exterior layer in the wall type. or specify a wall covering in the room. Then select the paint color from one of the paing catalogs as the material Thank you, @Joe_Carrick I appreciate the response. I must not have communicated my question clearly. I am not trying to apply a new paint color to the wall. I am trying to determine what paint/material has already been applied to an existing wall surface in the plan. I’m working in an older plan and cannot remember what paint color/material was previously assigned to a particular wall. Grateful for you. Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted May 20 Solution Share Posted May 20 Select the Wall and open the dialog. Then select the materials tab Link to comment Share on other sites More sharing options...
DefinedDesign Posted May 20 Author Share Posted May 20 30 minutes ago, Joe_Carrick said: Select the Wall and open the dialog. Then select the materials tab That is what I thought, but for some reason I don't see a color listed. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 20 Share Posted May 20 6 minutes ago, DefinedDesign said: That is what I thought, but for some reason I don't see a color listed. Maybe it was never added to the Wall. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted May 20 Share Posted May 20 You should be able to use the "define material" (aka rainbow) tool in a camera view to see what material is being used. 1 Link to comment Share on other sites More sharing options...
