PJS-59 Posted Monday at 07:51 PM Share Posted Monday at 07:51 PM I am trying to work with what dimensions are on what layers. Does anyone know if the automatic Interior and Exterior Dimensions can be placed automatically on different layers? Example: Automatic Exterior Dimensions --> Layer: Dimensions, Exterior Auto Dimension Room -- Layer: Dimension, Room Leaving Manual Dimensions and Temporary Dimension on Layer: Dimensions, Plan I can not find anything in Default Settings to allow this. Thank you Link to comment Share on other sites More sharing options...
DBCooper Posted Tuesday at 02:26 AM Share Posted Tuesday at 02:26 AM I don't know if you can. You can control the layer your dimensions go on through your dimension defaults and you can quickly change these using saved plan views. I don't think you can specify that the auto room and auto exterior go on to different layers though. The best way to do this is to change the current dimension layer, generate your room dimensions, and then change it back to what you want for other dimensions. Someone else might have some better ideas though. Link to comment Share on other sites More sharing options...
PJS-59 Posted 20 hours ago Author Share Posted 20 hours ago It sounds as if this may be a feature upgrade that is needed. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 20 hours ago Share Posted 20 hours ago (edited) You actually CAN do what you want. The simple fact is that Chief automatically creates Auto Dimensions for every dimension Default that you have set up, whether you are currently using that default or not, and whether the layer is currently displayed or not. What this means for you is this: All you need to do is turn Auto Dimensions OFF for your currently Active Dimension Default, and then make sure you have 2 other dimension defaults set up, one to create your Auto Exterior Dimension and place them onto the desired layer, and one to create your Auto Interior Dimensions and place them onto the desired layer. This will leave you with 3 Dimension Defaults: 1. Your Active Dimension Default which should be set to use your "Dimensions, Manual" layer 2. Your Auto Exterior Dimension Default which should be set to use your "Dimensions, Exterior" layer 3. Your Auto Room Dimension Default which should be set to use your "Dimensions, Room" layer Just make sure all 3 associated dimension layers are turned on in your current view and you should be good to go. Edited 20 hours ago by Alaskan_Son Link to comment Share on other sites More sharing options...
PJS-59 Posted 19 hours ago Author Share Posted 19 hours ago Thank you, but there are a few problems with this issue: When I select an auto-exterior dimension, in X-17, I get a warning when I change the layer. It turns off the auto-exterior dimensions. It also only changes the layer for the one dimension. Am I missing something? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 19 hours ago Share Posted 19 hours ago 32 minutes ago, PJS-59 said: Thank you, but there are a few problems with this issue: When I select an auto-exterior dimension, in X-17, I get a warning when I change the layer. It turns off the auto-exterior dimensions. It also only changes the layer for the one dimension. Am I missing something? Yes. Sound like perhaps you don't fully understand Dimension Defaults. I just sent you a P.M. Link to comment Share on other sites More sharing options...
Chrisb222 Posted 3 hours ago Share Posted 3 hours ago 16 hours ago, PJS-59 said: Am I missing something? You're seeing the warning because your currently selected dimension default has auto dimensions turned off. You need the change which dimension default is currently active to the one that has auto dimensions turned on. To use this method you'll need to change your current Active Dimension Default to the dimension you want to generate, then back to your normal drawing dimension default to resume normal drawing. Set everything up like Michael described Add the Active Dimension Default Control drop-down menu to your toolbar (see screenshot) Before generating auto dimensions, go to the drop-down and select the dimension default for the auto dimension you want to generate Generate the dimensions Go back to the drop-down and select your normal dimension default Add the Active Dimension Default Control tool to your toolbar: Link to comment Share on other sites More sharing options...
