Mona_Sh Posted Friday at 10:08 PM Share Posted Friday at 10:08 PM How to control where the file is saved in version 17? I am working in version 17. I started a new project directly from dashboard. In order to find the location that this file is saved, I tried using "save as" under File tab but it is not available. Then I tried "make a copy" under file tab. It made a copy but didn't provide the location that files are automatically saved. afterwards I checked preferences under edit tab. in there, under "General" section, under "folder" I found the address of Data folder where it saved the back up versions of my file under "Archives" folder. I copied the latest saved version into my desired location. My question is, did they eliminate the "save as" option under File tab? Is there a better way to find the location of the file and relocate it? or is there a way to designate the desired location upon creation of the file? Link to comment Share on other sites More sharing options...
Mark3D Posted Friday at 10:34 PM Share Posted Friday at 10:34 PM Project management is on by default in x17 so things look different but depending on what your are doing you might want to turn it of in preference's and go back to save as option 1 Link to comment Share on other sites More sharing options...
DBCooper Posted Saturday at 05:31 AM Share Posted Saturday at 05:31 AM Like Mark said, you can always turn it off if you prefer to do it the old way: https://www.chiefarchitect.com/support/article/KB-03210/enabling-or-disabling-project-management.html If you actually want to learn how to use it, maybe start here: https://www.chiefarchitect.com/videos/watch/10299/x17-file-project-management.html https://www.chiefarchitect.com/support/article/KB-03217/working-with-the-project-browser-using-project-management.html Link to comment Share on other sites More sharing options...
Renerabbitt Posted Sunday at 04:40 AM Share Posted Sunday at 04:40 AM See this video: 1 1 Link to comment Share on other sites More sharing options...
Mona_Sh Posted 11 hours ago Author Share Posted 11 hours ago On 3/6/2026 at 2:34 PM, Mark3D said: Project management is on by default in x17 so things look different but depending on what your are doing you might want to turn it of in preference's and go back to save as option Thank you! Link to comment Share on other sites More sharing options...
