Larry_Sweeney Posted 6 hours ago Share Posted 6 hours ago As the title says, I have a wide doorway that I want to angle the two top corners to match the roof pitch. Do I need to use a "pass-thru" instead of a "doorway" even though I want the opening to go all the way to the floor? The reason I'm asking about a pass-thru is that you have the "shape" option using a "pass-thru" and with a doorway you don't or is there another option to deal with my question? I'm having a "elder's brain fog". Link to comment Share on other sites More sharing options...
DBCooper Posted 5 hours ago Share Posted 5 hours ago You could also use a "triangle arch" set to either left or right side. Still have to fuss with the arch height to get the right slope though. Not sure why we don't have the shape options for doors though. Might want to send in a feature request for this. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted 2 hours ago Author Share Posted 2 hours ago Yes, that works for one side, but my opening is angled to the slope of the roof at both top corners of the doorway. I also agree as to why they don't have the "shape" option for the doorways. Link to comment Share on other sites More sharing options...
DBCooper Posted 2 hours ago Share Posted 2 hours ago You should be able to just a pass-thru then. If you set it on the floor and remove the sill/threshold, it should look ok. Link to comment Share on other sites More sharing options...
