Frenchy1 Posted January 24 Share Posted January 24 (edited) Hi all, can anyone create a bullnose veranda roof that looks like the attached? For now I have ended up doing it in a 3D solid with a moulded polyline, but it's making the software very laggy. Edited January 24 by Frenchy1 Link to comment Share on other sites More sharing options...
JKEdmo Posted January 24 Share Posted January 24 15 minutes ago, Frenchy1 said: Hi all, can anyone create a bullnose veranda roof that looks like the attached? For now I have ended up doing it in a 3D solid with a moulded polyline, but it's making the software very laggy. I did a quick test roof using the curved roof option (X17 plan attached). Seems promising. I've never done a roof like this before but might point you in the right direction. - Jim TEST ROOF.plan Link to comment Share on other sites More sharing options...
Frenchy1 Posted January 24 Author Share Posted January 24 Thanks so much. It's close, but the radius just needs to be so much tighter and then flat on the top. Link to comment Share on other sites More sharing options...
Mark3D Posted January 24 Share Posted January 24 (edited) Try this its a 3d molding line with stacked moldings Bullnose veandah 2100.plan Edited January 25 by Mark3D Link to comment Share on other sites More sharing options...
Frenchy1 Posted January 24 Author Share Posted January 24 1 hour ago, Mark3D said: Try this its a 3d molding line with stacked moldings Bullnose veandah.plan 3.99 MB · 1 download Will do, thanks so much. Link to comment Share on other sites More sharing options...
Frenchy1 Posted January 24 Author Share Posted January 24 1 hour ago, Mark3D said: Try this its a 3d molding line with stacked moldings Bullnose veandah.plan 3.99 MB · 1 download Hi Mark3D, would you be able to convert this so I can just use it down one side of the building? I haven't actually worked with stacked mouldings so I don't know how to adapt it. Link to comment Share on other sites More sharing options...
Frenchy1 Posted January 24 Author Share Posted January 24 2 minutes ago, Frenchy1 said: Hi Mark3D, would you be able to convert this so I can just use it down one side of the building? I haven't actually worked with stacked mouldings so I don't know how to adapt it. Also 2100mm in width Link to comment Share on other sites More sharing options...
Frenchy1 Posted January 24 Author Share Posted January 24 1 hour ago, Mark3D said: Try this its a 3d molding line with stacked moldings Bullnose veandah.plan 3.99 MB · 1 download It's all good, Mark. I worked it out. Thanks so much. Great work. Link to comment Share on other sites More sharing options...
Mark3D Posted January 24 Share Posted January 24 1 minute ago, Frenchy1 said: Also 2100mm in width You just need to redraw the section line I used for the roof section of the molding polyline to get the 2100 width and adjust its position on the molding polyline. let me know if it's to tricky Bullnose veandah.plan Link to comment Share on other sites More sharing options...
Doug_N Posted January 24 Share Posted January 24 This was just playing with making an upper an lower segment roof with different pitches for each segment, a really steep slope on the lower roof, and then curving the lower section. Seemed to work. Link to comment Share on other sites More sharing options...
Mark3D Posted January 24 Share Posted January 24 Hips and ridge capping 1 Link to comment Share on other sites More sharing options...
Frenchy1 Posted January 25 Author Share Posted January 25 (edited) Thanks everyone. I need to look more into stacked mouldings I think. They don't seem to be that intuitive to me but I'm stupid Edited January 25 by Frenchy1 Link to comment Share on other sites More sharing options...
Mark3D Posted January 25 Share Posted January 25 They are a bit complex i have been trying to do video showing it as i spotted as a good topic for au users and getting stressed with it i need to relax and have another go when I am calm. Link to comment Share on other sites More sharing options...
Frenchy1 Posted January 25 Author Share Posted January 25 Are you an user? Not many of us. RAB made a video that included some stacked mouldings but it's still a bit you know fudgy trying to make it work Link to comment Share on other sites More sharing options...
Mark3D Posted January 25 Share Posted January 25 (edited) Try this video the audio is a bit up and down but should help If you still cannot do it send me your plan will have a go Edited January 27 by Mark3D Link to comment Share on other sites More sharing options...
Mark3D Posted January 26 Share Posted January 26 On 1/25/2026 at 4:57 PM, Frenchy1 said: Are you an user? Not many of us. RAB made a video that included some stacked mouldings but it's still a bit you know fudgy trying to make it work Typo I think you are asking if I am a AU user yes my signature shows that also Link to comment Share on other sites More sharing options...
