Designers_Edge Posted October 31, 2025 Share Posted October 31, 2025 I am unable to select any line in the wall elevation sent to layout to edit. I have saved and closed out of the program and rebooted my computer, but still can't select the lines I need to edit. Has anyone else experienced this? Sharon Olsen, AKBD X17 iMac 2023, iOS 26.0.1 Link to comment Share on other sites More sharing options...
DBCooper Posted October 31, 2025 Share Posted October 31, 2025 (edited) Did you send the view as "plot lines"? You can only edit plot lines. Edited October 31, 2025 by DBCooper 1 1 Link to comment Share on other sites More sharing options...
MoeGia Posted November 1, 2025 Share Posted November 1, 2025 If your plot line view ports overlap, you won't be able to select line for editing in one of them. Once you pull the edge back you'll have access to the lines. 1 Link to comment Share on other sites More sharing options...
Designers_Edge Posted November 3, 2025 Author Share Posted November 3, 2025 Thank you so much for answering me. I did not send as plot lines, so there's the problem. Will resend the view. Sharon Link to comment Share on other sites More sharing options...
DBCooper Posted November 3, 2025 Share Posted November 3, 2025 FYI, you don't actually need to resend the view. You can open the layout box dialog and change the view type there. Link to comment Share on other sites More sharing options...
