Demo Plan Best Practice
Ringos
Trying to stay up-to-date on best practices. Chief makes a video of a process but then I don't ever see an update for years. I am wondering if there is any new developments in the chief program that makes this better?
I've been using this as-built to demo to new construction method
https://www.chiefarchitect.com/videos/watch/9867/remodel-process.html
Which is creating the as-built, then duplicating that and continuing to develop the demo and new construction, then overlaying the as-built on the remodel.
What has been the best for others?
2 hours ago, Ringos said:
SHCanada. When you hatch over a wall, it is not removed, right? So it still shows up on elevations and renderings?
I remove the wall or portion thereof if I am going to render(sometimes it is just a wall in a closet or bathroom or in a hall, which may not get rendered, so the wall does not need actually be removed), and just leave the hatched polyline on the plan view. I dont do as built renders, only proposed.
Below is walls cut back, and pline left in its place, as there were renders showing the dining from the kitchen
Edited by SHCanada2
2 minutes ago, Ringos said:
Are you just using cad box with hatching then instead of the wall hatch tool?
exactly. I pick which one to use depending on it it matters if there is still a "wall" there or not. For the wall hatching tool, if you want only part of the wall, you have to break up the wall, just as aa FYI
