decorators3 Posted August 26, 2025 Share Posted August 26, 2025 I have the first floor and foundation but when I build new floor it goes to three ?? when I tried again it went to four where is two??? I am definitely on the first floor - using x 17 any suggestions. I also reset all defaults again but nothing changed Levina Link to comment Share on other sites More sharing options...
Doug_N Posted August 26, 2025 Share Posted August 26, 2025 Please post the plan file. Link to comment Share on other sites More sharing options...
decorators3 Posted August 26, 2025 Author Share Posted August 26, 2025 4 hours ago, Doug_N said: Please post the plan file. - not sure of the project management yet in x 17 - this may not open. joanne cochrane - Copy 1.zip Link to comment Share on other sites More sharing options...
decorators3 Posted August 26, 2025 Author Share Posted August 26, 2025 12 minutes ago, decorators3 said: - not sure of the project management yet in x 17 - this may not open. joanne cochrane - Copy 1.zip 1016.89 kB · 0 downloads when I tried to open this - instead of opening under x 17 it said it was opening under x 16 and system asked me to upgrade, really strange Link to comment Share on other sites More sharing options...
DBCooper Posted August 26, 2025 Share Posted August 26, 2025 (edited) As far as I can tell, there is nothing wrong with your plan. My guess is that when you try to open the plan (maybe from file explorer instead of from within the program) that your ".plan" files are still associated with X16. The plan is definitely an X7 plan so it can't be opened in X16. You can associate your files with X17 if you want to avoid this problem. Here is a tech article explaining how: https://www.chiefarchitect.com/support/article/KB-01131/associating-project-plan-layout-and-library-files-with-a-specific-version-of-chief-architect-or-home-designer.html As for the floor problems, you have a blank second and third floor. You may have accidently made a blank second floor at first and then if you make any more new floors they will also be blank. All you probably need to do is just delete the blank second and third floor and then you can make a new second floor using the first floor walls. Edited August 26, 2025 by DBCooper Link to comment Share on other sites More sharing options...
decorators3 Posted August 26, 2025 Author Share Posted August 26, 2025 51 minutes ago, DBCooper said: As far as I can tell, there is nothing wrong with your plan. My guess is that when you try to open the plan (maybe from file explorer instead of from within the program) that your ".plan" files are still associated with X16. The plan is definitely an X7 plan so it can't be opened in X16. You can associate your files with X17 if you want to avoid this problem. Here is a tech article explaining how: https://www.chiefarchitect.com/support/article/KB-01131/associating-project-plan-layout-and-library-files-with-a-specific-version-of-chief-architect-or-home-designer.html As for the floor problems, you have a blank second and third floor. You may have accidently made a blank second floor at first and then if you make any more new floors they will also be blank. All you probably need to do is just delete the blank second and third floor and then you can make a new second floor using the first floor walls. Thank you I appreciate your input and link Cheers Link to comment Share on other sites More sharing options...
