Doors Interior Vs. Exterior
PitMan71
Go to solution Solved by DBCooper,
@PitMan71The only way to change the door designation from interior to exterior would be to delete and replace the door. The interior/exterior depends on the Room Type on either side of the door, so it was likely placed before specifying the porch as a porch room.
However, there is a setting that will allow you to control the casing and materials on either side of the door. You can open the Door Specification and at the bottom of the General panel check the box for "Separate Trim and Materials on Each Side".
I hope this helps!
This is good to know. Thanks.
17 minutes ago, DBCooper said:
Just check the box for "separate trim and materials"
Thanks for the information.
Get this right if you want an exterior door on the schedule/material list. Interior vs exterior door thicknesses, cores, thresholds, seals, etc. are different.
