PitMan71 Posted August 21 Share Posted August 21 Is there a way to change a door designation from interior to exterior in the door dbx? I have door exiting the home onto a porch that is going in as an interior door making it to where I can't control the casing on both sides. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted August 21 Solution Share Posted August 21 No, but you don't need to in order to change the casing. Just check the box for "separate trim and materials". 1 1 Link to comment Share on other sites More sharing options...
ChiefTylerL Posted August 21 Share Posted August 21 @PitMan71The only way to change the door designation from interior to exterior would be to delete and replace the door. The interior/exterior depends on the Room Type on either side of the door, so it was likely placed before specifying the porch as a porch room. However, there is a setting that will allow you to control the casing and materials on either side of the door. You can open the Door Specification and at the bottom of the General panel check the box for "Separate Trim and Materials on Each Side". I hope this helps! 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted August 21 Author Share Posted August 21 15 minutes ago, ChiefTylerL said: The interior/exterior depends on the Room Type on either side of the door, so it was likely placed before specifying the porch as a porch room. This is good to know. Thanks. 17 minutes ago, DBCooper said: Just check the box for "separate trim and materials" Thanks for the information. Link to comment Share on other sites More sharing options...
CharlesVolz Posted August 21 Share Posted August 21 38 minutes ago, ChiefTylerL said: The interior/exterior depends on the Room Type on either side of the door, Get this right if you want an exterior door on the schedule/material list. Interior vs exterior door thicknesses, cores, thresholds, seals, etc. are different. 1 Link to comment Share on other sites More sharing options...
