para-CAD Posted July 27, 2025 Share Posted July 27, 2025 See attached image Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 27, 2025 Share Posted July 27, 2025 If you change the title and save the schedule definition in your user library - or in your default plan template (CAD Detail) - then it will have the name you want. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted July 27, 2025 Share Posted July 27, 2025 If you already have your schedules in your plans (or even better, in cad details), you need to change them there. Regardless of where they are in the plan, you can always find and change them quickly using the project browser. If you are saving schedules to the library and then placing them in your plan, just edit the names in the library using open object and you should be good to go. If you are placing new schedules using the schedule tool, you can change the names in your schedule defaults. If you do this in your template plans, then you won't have to do this each time you start a new plan and place a schedule. If you are making the same custom schedules over and over again for every new plan, I highly recommend that you create them only once and then save them in the library or put them into a cad detail so they are always available. 1 Link to comment Share on other sites More sharing options...
