N on north arrow rotates with layout rotation
SHCanada2
Go to solution Solved by Alaskan_Son,
17 hours ago, Joe_Carrick said:
Send the Plan to Layout and the rotate the Layout Box
thats what I had done, above
just place the North Arrow on the Layout page (scale as needed)
it is greyed out in the layout menu
  • Solution
That behavior is controlled by the Text Style being used for your North Pointer's Layer.  Edit the Text Style so that it is set to Rotate with Plan.  If you need that setting unchecked for something else, then create a NEW Text Style and set it to Rotate with Plan.
