JKEdmo Posted June 21, 2025 Share Posted June 21, 2025 Does anybody know why the load CAD block / custom muntin tool you use on window lites does not build the custom muntins to the centerline of the linework? Is there a workaround for this or am I doing something wrong? Pics below. Thanks, Jim Before: After loading CAD block to window: Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 21, 2025 Share Posted June 21, 2025 Apparently it's programmed to be offset to one side, maybe even a little more. You shoudlprobably report this to Chief as a "Bug". Link to comment Share on other sites More sharing options...
JKEdmo Posted June 22, 2025 Author Share Posted June 22, 2025 15 minutes ago, Joe_Carrick said: Apparently it's programmed to be offset to one side, maybe even a little more. You shoudlprobably report this to Chief as a "Bug". Thanks for quick response. I will do so. - Jim Link to comment Share on other sites More sharing options...
robdyck Posted June 22, 2025 Share Posted June 22, 2025 I did a quick experiment. While my cad block lines were exactly drawn corner to corner, I got similar unexpected results at each corner for the relationship between the center of the line and the center of the muntin. Upon inspection, I can see that for these muntins, the cad lines represent the top edge of the muntin. So, I can adjust the cad lines to move to the top edge and re-load the muntin. First Try: 2nd Try: Link to comment Share on other sites More sharing options...
JKEdmo Posted June 22, 2025 Author Share Posted June 22, 2025 1 hour ago, robdyck said: So, I can adjust the cad lines to move to the top edge and re-load the muntin. Thanks Robert for looking at this. I sent this in yesterday to tech support. To me it seems like it should just build to the centerline. If Chief has a follow-up, I'll post the reply. Jim 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted June 23, 2025 Author Share Posted June 23, 2025 21 hours ago, JKEdmo said: I sent this in yesterday to tech support. Follow-up to this... Chief responded and said they would review: Hi Jim, Thank you for contacting Chief Architect Support. I tested it a bit myself, and it does look like custom muntins load in a bit inconsistently based on their position/angle. I'll go ahead and report this to our developers, and let you know what they say, or whether this is something they end up needing to fix. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 25, 2025 Share Posted June 25, 2025 I had reported this some time ago. I know this was not an issue in like X14, maybe ok in X15, but went bad in X16 I believe. Link to comment Share on other sites More sharing options...
