JKEdmo Posted June 11, 2025 Share Posted June 11, 2025 I have a pretty complex basement foundation wall with existing masonry below and stud framing above. In addition, there's new interior full height furring. A lot going on: I show the upper wall in plan, but I wanted to also clarify in plan what's going on below. Then, it occurred to me I can just break the wall for a short length and switch that pony wall section to "Display in Plan View" to show the lower wall. A couple of CAD break lines and I'll wrap up by adding a plan note to clarify... Nothing earth shattering, but I thought pretty nifty. Jim 3 Link to comment Share on other sites More sharing options...
ACADuser Posted June 11, 2025 Share Posted June 11, 2025 Clever solution. I suppose you could capture that with CAD Detail from View & make cad block. Then close the wall again. That way it would not show up on Electrical & HVAC plan views. Just a thought. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 18, 2025 Share Posted June 18, 2025 On 6/11/2025 at 11:38 AM, JKEdmo said: complex basement foundation Your plan set should include a "foundation plan" that only shows the concrete foundation and footing, ie the lower part of the wall only, since your excavator and concrete forms guy don't care about anything else. Then once the foundation is poured and your rough carpenter starts, he can work from another "finished basement" plan. On that plan page show only the upper wall type, since that's all he cares about. No need for anything else, in my opinion. Link to comment Share on other sites More sharing options...
JKEdmo Posted June 18, 2025 Author Share Posted June 18, 2025 1 hour ago, Michael_Gia said: No need for anything else, in my opinion. Thanks for your input. - Jim 2 Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 18, 2025 Share Posted June 18, 2025 1 hour ago, Michael_Gia said: Your plan set should include a "foundation plan" that only shows the concrete foundation and footing, ie the lower part of the wall only, since your excavator and concrete forms guy don't care about anything else. Then once the foundation is poured and your rough carpenter starts, he can work from another "finished basement" plan. On that plan page show only the upper wall type, since that's all he cares about. No need for anything else, in my opinion. This is EXACTLY why I do my walkout basements on level 1, so we can isolate stem walls from custom pony walls in a stepped and furred foundation Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 21, 2025 Share Posted June 21, 2025 I use several walls, the daylight pony wall, with a halfwall or full furring wall on the inside on layer 0. Works very well, has for over 5 years, but you need to pay attention to your furring wall settings to make sure you are not removing the sq.ft. from the room. Looks good, Jim! Link to comment Share on other sites More sharing options...
