mtldesigns Posted June 8, 2025 Share Posted June 8, 2025 I've been doing design for almost 40 years (geez, didn't realize I was that old), back in the drafting board days, and even with AutoCAD and Chief cad, when height of a object won't fit on a paper, we do cuts with cut lines (40 yrs and don't know what these are called, I just did them..). Can we do this in Chief on a section view? Duval County Florida is requiring a full section of every wall at 3/4" scale. Well, you try to get a 3 story house at that scale in the vertical with dims. So I was thinking and wondering if we had this possibility? The only way I can figure this out in Chief is to stack the same view and just shrink each one and stack... Link to comment Share on other sites More sharing options...
JKEdmo Posted June 8, 2025 Share Posted June 8, 2025 26 minutes ago, mtldesigns said: I've been doing design for almost 40 years (geez, didn't realize I was that old), back in the drafting board days, and even with AutoCAD and Chief cad, when height of a object won't fit on a paper, we do cuts with cut lines (40 yrs and don't know what these are called, I just did them..). Can we do this in Chief on a section view? Duval County Florida is requiring a full section of every wall at 3/4" scale. Well, you try to get a 3 story house at that scale in the vertical with dims. So I was thinking and wondering if we had this possibility? The only way I can figure this out in Chief is to stack the same view and just shrink each one and stack... Michael, My first thought is I might try to do this with Layout boxes on the wall section sheet, each a box partial section (slice) of the full wall section. I've done this a number of time in Autocad (Viewports) and always works pretty well. Jim Link to comment Share on other sites More sharing options...
mtldesigns Posted June 8, 2025 Author Share Posted June 8, 2025 3 minutes ago, JKEdmo said: Layout boxes on the wall section sheet, each a box partial section (slice) of the full wall section. Exactly what I did Jim, that's what I was say in my OP "The only way I can figure this out in Chief is to stack the same view and just shrink each one and stack..." Kind of a pain but was pretty easy. I know AutoCAD Plant 3D has this option, and the dims stay true... just was throwing it out there. Thanks, glad to see others are working on a Saturday night too. Link to comment Share on other sites More sharing options...
JKEdmo Posted June 8, 2025 Share Posted June 8, 2025 23 minutes ago, mtldesigns said: Thanks, glad to see others are working on a Saturday night too. Who said I was working? 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted June 8, 2025 Share Posted June 8, 2025 18 minutes ago, JKEdmo said: Who said I was working? BTW, I do it like Jim. Link to comment Share on other sites More sharing options...
