Solution Ed_Orum Posted May 22, 2025 Solution Share Posted May 22, 2025 The goal is to have a patio door with standard glass. My glass is green. What's up with that? Thanks in advance, Lane 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 22, 2025 Share Posted May 22, 2025 I suspect you painted the glass or modified the standard glass material to be green. Link to comment Share on other sites More sharing options...
DBCooper Posted May 22, 2025 Share Posted May 22, 2025 Maybe you made the standard glass green, but I kind of doubt it. My guess is that you made the door style "panel" instead of "glass panel". A "panel" style door will not use the glass material. If it's not one of those, you should probably post the plan. Also, seems kind of silly to mark your question as the solution. Link to comment Share on other sites More sharing options...
Ed_Orum Posted May 22, 2025 Author Share Posted May 22, 2025 I fixed it, Closed the program then opened it up again, deleted the door, then added a door again and changed the materials. Link to comment Share on other sites More sharing options...
