dbarbee Posted May 16 Share Posted May 16 I am using Chief 16. I wanted to know if there was a way to get my line weights for the floor plan view to look like pencil sketches or technical drawings. I don't know the exact terminology, so I have provided pictures. Thanks! Link to comment Share on other sites More sharing options...
MPDesign Posted May 17 Share Posted May 17 You can make it to look like your last picture. Solid wall type fill, turn off casing inside and outside. Pick a script type font. Link to comment Share on other sites More sharing options...
dbarbee Posted May 17 Author Share Posted May 17 Where would I go specifically for that? I know it might be obvious, but I am still learning the software. Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 17 Share Posted May 17 14 hours ago, dbarbee said: I wanted to know if there was a way to get my line weights for the floor plan view to look like pencil sketches or technical drawings. You can get very close to #2. Select one door, then all doors in the plan using Match Properties, and set the 3D Display to Show Open: Then go to: 3D > Create Orthographic View > Orthographic Full Overview 3D > View Direction > Top View 3D > Rendering Techniques > Hand Drawn Lines 3D > Camera View Options > Cross Section Slider Check the top option and set the cut to around 60" or wherever you see the door header cropped out, so the doors look right: Send this to layout, Live View > Update on Demand Return to the floor plan, and turn off all layers except Room Labels and Rooms, Interior Dimensions: Send this to layout and position in place over the previously sent view: Voila! 1 Link to comment Share on other sites More sharing options...
dbarbee Posted May 17 Author Share Posted May 17 This is awesome!!! I never knew about the top direction view. Thanks! Link to comment Share on other sites More sharing options...
MollyNDG Posted May 19 Share Posted May 19 On 5/17/2025 at 6:49 AM, Chrisb222 said: You can get very close to #2. Send this to layout and position in place over the previously sent view: You can also turn on Display Poche in Edit Active View if you want to display a fill on the walls. Link to comment Share on other sites More sharing options...
