BTWKNZ Posted May 15 Share Posted May 15 Hello All Just a passion project, but I'm trying to create a 1200mm x 1200mm x 1200mm (47.24409 inch) window on top of the roof. It has no floor letting in light into the space. I've been able to peel back the roof by creating a square poly at 1200mm x 1200mm and centering it over the roof, then cutting the roof plane and dragging them to match the square poly, leaving the open roof, but can't figure out how to create the window. I've tried to create a 3rd floor, but unable to define a wall with no floor to be able to put windows in. I've attached the plan file. Any help would be most appreciated. The Cork and Cap v2.plan The Cork and Cap v2.plan Link to comment Share on other sites More sharing options...
ericepv Posted May 15 Share Posted May 15 Build it as a separate floor: Build / Floor / Build New Floor - Select 'Make new blank plan for the 2nd floor' and draw in your walls then add windows and roof. Select "open below' as your room type. - Eric 1 Link to comment Share on other sites More sharing options...
Rich_Winsor Posted May 15 Share Posted May 15 Link to comment Share on other sites More sharing options...
MPDesign Posted May 15 Share Posted May 15 As Eric said build a 2nd floor. I attached a copy for you to look at. 471651323_TheCorkandCapv3.plan 1 Link to comment Share on other sites More sharing options...
BTWKNZ Posted May 15 Author Share Posted May 15 47 minutes ago, ericepv said: Build it as a separate floor: Build / Floor / Build New Floor - Select 'Make new blank plan for the 2nd floor' and draw in your walls then add windows and roof. Select "open below' as your room type. - Eric Ahhhhh open below!!!! Of course thanks Eric Link to comment Share on other sites More sharing options...
BTWKNZ Posted May 15 Author Share Posted May 15 14 minutes ago, MPDesign said: As Eric said build a 2nd floor. I attached a copy for you to look at. 471651323_TheCorkandCapv3.plan 7.22 MB · 0 downloads Thank you MPD! I'll have a look in the morning (downunder) appreciate the help Link to comment Share on other sites More sharing options...
