Mouse wheel zoom speed?
Go to solution Solved by Larry_Sweeney,
I opened X16 this morning and my mouse wheel "zoom speed" has really changed. It was working correctly when I shut it off yesterday. Before I held my ctrl button down and when moving my mouse wheel, my zoom would move my plan in or out very quickly. Now, since opening up the plan this morning, the zoom hardly moves my plan in or out (very small increments) when holding the ctrl button down while moving the mouse wheel. Is there a setting somewhere that needs to be reset in the program or is this a problem with my "CadMouse Pro"?
Open 'Settings' in Windows and navigate to 'Devices' and select 'Mouse' from the menu on the left. From there, you can adjust the cursor speed.
  • Solution
In troubleshooting, I shut down the computer and restarted it and now "things" with my mouse seems to be working correctly. I just got a new computer setup a couple of days ago and I'm wondering if that could be "some" of the issues I'm having?
  • 4 weeks later...
Whats happening is the distance of the camera is changing as you go. When it gets a bit irratic, open the plan view and look at your camera, adjust the length of the view line to the spot where you are working, then go back to the camera.
Here is an example.... As you can see, the camera line is off in the distance with the erratic image, and in the other image the line has been brought to the area of focus in the functional image when the tree and garden area are your focus.
Functional
erratic
Does that make sense to you?
