Layout Default Annotation Set doesn't include Arrows.
amddrafting
17 minutes ago, amddrafting said:
Why in God's green earth is this a thing at all?  Why is it not under "Markers" like in the plan file?  Chief devs, what's the deal?
Well it would be very odd to do annotations in Layout, is that what you are trying to do?
They are not... they are in the defaults and in order to change it for your annotation set you have to change it in the defaults and then "save your active defaults" to a new set.  And you can't overwrite your current set so you have to make a new one with a different name, delete the old one and then rename the new set back to the old name.
This is how it looks in the plan file...
Here's where you have to change it in layout file
Create a "Redlines" annotation set for revision clouds and text that can be easily set for making notes to give to my staff.
1 minute ago, Renerabbitt said:
ah okay a singular use case, I get you. Also in case you didnt know, redlines notes can actually bind to objects in the z axis in a 3d view so you can make 3d notes:
Yeah that's cool for sure!  We use a team to review out layout sets for each other and rather than putting it in the plan file itself we find it easier to add notes to the layout sheets and delete them as they are addressed.  However, having an annotation set makes it easier than having to copy paste to keep the red text, etc.  Just an efficiency thing.  Just think if we have annotation sets in Layout we should have arrows associated the same as in plan files... seems like common sense to me really.
Quote
Never noticed it was missing before but I agree with you that it should probably be there.
Did you send Chief a bug report or feature request?  I am pretty sure they won't respond to a random post like this.
