PitMan71 Posted Thursday at 04:22 PM Share Posted Thursday at 04:22 PM Is there a way to have chief display or generate roof decking pattern? Ultimately I would like to see a layout with quantity. I have done some searching on this and I am not finding anything. Thanks Link to comment Share on other sites More sharing options...
VHampton Posted Thursday at 11:29 PM Share Posted Thursday at 11:29 PM Not sure if your question is regarding a visual for the structure or the finished deck area. If for the structure... use a grid pattern w/ an offset. Set the size to 48" x 96". This is typically how roof sheathing (decking) is laid out. In a grid pattern. If on the other hand this is for illustrating deck boards... 3-1/2" wide hatch can be used or 5/4 x 4 ....or 5-1/2" wide hatch for 5/4 x 6. Apologies if this response is stating the obvious. One only needs to make a poly-line in order to create the skin to represent the roof surface. That poly-line can be given a label which indicates the precise surface area. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted 18 hours ago Share Posted 18 hours ago So far as I can tell you can create a schedule to show the square footage of each roof plane and then divide that by 32 to get number of sheets. It would be a cool feature if that was built in to the material master list and you could add a value of 15% for waste 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted 18 hours ago Author Share Posted 18 hours ago 15 hours ago, VHampton said: If for the structure... use a grid pattern w/ an offset. Set the size to 48" x 96". This is typically how roof sheathing (decking) is laid out. In a grid pattern. Yes.... I was referring to plywood decking on the roof and subfloor. I would like to see a plywood decking layout with a quantity. Common takeoff methods are to calculate the roof area and divide by 32.... it would great though is the program actually placed the plywood on the roof in a way that could be displayed showing takeoff quantity is accurate with whole pieces and cut pieces. Sounds like it may be a good enhancement request. Link to comment Share on other sites More sharing options...
Chrisb222 Posted 15 hours ago Share Posted 15 hours ago 2 hours ago, PitMan71 said: it would great though is the program actually placed the plywood on the roof in a way that could be displayed Not sure exactly what you're after, but if it's just a visual of the plywood in 3D and you can calculate the qty another way, that's easily doable: Change your OSB material to have an offset grid, then in a 3D view use the Delete Surface tool (3D > Delete Surface) to temporarily remove the surface material (which doesn't truly delete it, it regenerates automatically). 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted 12 hours ago Author Share Posted 12 hours ago I will check into this. Thanks. Link to comment Share on other sites More sharing options...
