Roof & Or Room Will Not Delete Or Rebuild?
ACADuser
plan attached.
I decided to reconfigure the garage to side load. Single car on the upper left of plan.
So I went to 1st floor & broke exterior wall & pulled wall left to 20'8"
& continued with 1st floor shape of garage.
The went to foundation & did same.
Moving to roof & deleted the roof over the garage.
At 2nd floor I changes the shape to ,match the first floor.
The tried to rebuild roof. None would rebuild on 2nd floor only first floor.
I tried to delete 2nd floor walls & attic wall appears & could not delete.
I rebuilt 2nd floor & no room definition or roof .
So what did I do wrong & hot to fix it.
Bash.zip
I typically use Edit Area for this types of plan change. You can draw a polyline around the area you would like to change and then hit the edit area all floors icon and drag, or use Transform/Replicate to move the area precisely. Using this method you won't get pieces of 'automatically generated attic walls with no room definition' which might be the reason a roof won't build; the program can't fine any walls to define the space.
I find the auto generated attic walls a little too helpful; it might be better if the defaulted to having a room definition. It's hard to see which walls are causing the problem without opening each one.
Thanks for the replies.
I found this morning that closing the drawing helped.
Larry showed that I have problems wit both garages.
Larry there was a garage on the left but disappeared when drawing was re-opened. although a hidden wall remained.
I was able to redraw the garage & the ROOM was created.
Maureen, as you can see on the attached photo dragging with the rectangle edit tool would not work on this room.
Thanks, I'll keep you posted
