capitaldesigns Posted March 22, 2025 Share Posted March 22, 2025 I imported a survey plan of a two acre sloped two acre lot that was drawn in AutoCAD. The problem I am having is the trying to do a perspective full overview. I get a warning "You have 22041 elevation points. The terrain interpolation will take a long time to generate. Would you like to use the linear interpolator instead?" I tried running the perspective full overview and it runs for hours. The file size of the imported survey plan is 38,441 KB. There are only 24 contour lines When I click on one of the contour lines I see that there are hundreds of edit handles along each line. Is there a way to smooth out each line by reducing the number of edit handles ? I'm hoping that might reduce the file size and allow me to do a perspective full overview. Has anyone experienced this before ? Thanks, Mike Link to comment Share on other sites More sharing options...
DBCooper Posted March 22, 2025 Share Posted March 22, 2025 Maybe you could draw an elevation spline on top of the imported contour lines and then get rid of them? Link to comment Share on other sites More sharing options...
Mark3D Posted March 22, 2025 Share Posted March 22, 2025 Some times with imported terrains you can get away mostly only using major contours that makes it easier for chief to handle Link to comment Share on other sites More sharing options...
