Double Fascia - Extended Piece
Ange822
Go to solution Solved by robdyck,
Hi there - I'm wondering if there is a way to have the top fascia piece cut horizontally so it doesn't extend past the bottom fascia.
I have played around with the different depth / options but think I am missing something.
Thanks in advanced! :)
1440999175_FasciaExtended-March112025.thumb.png.061cb3af271181620da48e80d303c703.png1994977986_FasciaExtended2-March112025.thumb.png.7f578ed90c3631a749bf89b86bf2c494.png2091576248_FasciaExtended3-March112025.thumb.png.9c9818af8ca8425ead3d90f6eb846ce4.png
On 3/11/2025 at 4:31 PM, ericepv said:
Open the DBX for the roof panel and go to the 'Options' tab. There you can specify either Square or Plumb Eaves.
Thank you for the recommendation, I already have "plumb" checked off in the "options" tab. :)
On 3/11/2025 at 4:38 PM, robdyck said:
Hi Ange, you could try copying that shadow board and set it to 1/16" thickness, Eaves Only, set it to an invisible material.
image.thumb.png.21a6e01e9f59e7587a1e4391ecb57108.pngimage.thumb.png.0aa4235d93eb53caa48ee4047839dbc0.png
Thanks Rob, this worked out perfectly! I just made a material that was 100% translucent! :)
 1285341023_FasciaExtended4-March132025.thumb.png.400c8344c0ba3d010d4d2d5939ebe04c.png
