JKEdmo Posted February 8, 2025 Share Posted February 8, 2025 Today I wanted to select all walls of a certain type (Interior 4 - NEW) in order to change to another type (Interior 4). I thought you could do this with the restrictive selection tool (with certain filters?), but I could not figure it out. I only got so far as selection all walls... Can somebody clue me in on this please? I think I'm missing something important with this tool. Thanks again, Jim Link to comment Share on other sites More sharing options...
DBCooper Posted February 9, 2025 Share Posted February 9, 2025 I don't think the restrictive selection tool looks at the "wall type". I think it only looks at other wall settings like attic, railing, invisible, etc. You might want to play around with a wall schedule instead. By default, it will group all of the walls based on the "wall type" and then you can use the "open row objects" tool to edit them all at once. Link to comment Share on other sites More sharing options...
Solution MarkMc Posted February 9, 2025 Solution Share Posted February 9, 2025 You can use the match properties tool, ctrl+J on my system or this icon. Other Properties, Automatic description should do the trick. Link to comment Share on other sites More sharing options...
JKEdmo Posted February 9, 2025 Author Share Posted February 9, 2025 10 hours ago, DBCooper said: You might want to play around with a wall schedule instead. Great idea. Thanks! Link to comment Share on other sites More sharing options...
JKEdmo Posted February 9, 2025 Author Share Posted February 9, 2025 3 hours ago, MarkMc said: You can use the match properties tool, ctrl+J on my system or this icon. Brilliant! Worked very well. Thanks, Jim Link to comment Share on other sites More sharing options...
