Why Is This Base In The Middle Of The Floor?
4hotshoez
That's weird.  I initially opened it in X7 and it didn't show up, then I opened it on X6 and it does.
It's coming from the angled wall in the foyer behind the fridge. I just moved that wall a bit then moved it back and it went away.
I messed around with it in X6 and I can't seem to get it to go away. I've had this problem in the past with the room divider walls, but whenever I pulled them back and then reconnected them, my problem went away. That doesn't seem to be the case in your plan. Hmm. I'm very obsessive compulsive about my plans and this would bug me to no end. Maybe submit the plan to tech support if no one figures it out? Also you seem to have a little rectangular hole in your ceiling. Maybe someone could fuss with that a bit. Good Luck Todd! I hope you get it figured out.
