4hotshoez Posted March 25, 2015 Share Posted March 25, 2015 It cuts across a room. Plan: https://www.dropbox.com/s/86fyxuz48zu5z18/PostedPlan02.plan?dl=0 Link to comment Share on other sites More sharing options...
Rosco2017 Posted March 25, 2015 Share Posted March 25, 2015 Hmm, I'm not getting that on my end. Let me poke around a bit. Link to comment Share on other sites More sharing options...
Athenian_CAD Posted March 25, 2015 Share Posted March 25, 2015 I see it in X6, but not X7.If you select it, the room to the left highlights, so it looks like a wall connection problem that was fixed in the newer version. Link to comment Share on other sites More sharing options...
MikeJG Posted March 25, 2015 Share Posted March 25, 2015 That's weird. I initially opened it in X7 and it didn't show up, then I opened it on X6 and it does. It's coming from the angled wall in the foyer behind the fridge. I just moved that wall a bit then moved it back and it went away. Link to comment Share on other sites More sharing options...
Rosco2017 Posted March 25, 2015 Share Posted March 25, 2015 I messed around with it in X6 and I can't seem to get it to go away. I've had this problem in the past with the room divider walls, but whenever I pulled them back and then reconnected them, my problem went away. That doesn't seem to be the case in your plan. Hmm. I'm very obsessive compulsive about my plans and this would bug me to no end. Maybe submit the plan to tech support if no one figures it out? Also you seem to have a little rectangular hole in your ceiling. Maybe someone could fuss with that a bit. Good Luck Todd! I hope you get it figured out. Link to comment Share on other sites More sharing options...
4hotshoez Posted March 25, 2015 Author Share Posted March 25, 2015 I have not down loaded X7 yet. I was concerned about it being slow in 3D and I have a slow computer to begin with. Thanks for checking it out for me. Link to comment Share on other sites More sharing options...
tommy1 Posted March 26, 2015 Share Posted March 26, 2015 Todd, it kinda looks like the only reason you have this is to get a different room label. If so, then I would delete it and just place text for the different room name. Just a quick fix. Link to comment Share on other sites More sharing options...
