Migaloo Posted Saturday at 05:37 PM Share Posted Saturday at 05:37 PM Is there a way to make concrete footings appear to be brick veneer in elevation views? Link to comment Share on other sites More sharing options...
SHCanada2 Posted Saturday at 07:08 PM Share Posted Saturday at 07:08 PM below ground footings? I suppose one could change the material from concrete to brick. You may wish to post an image of what you are trying to do Link to comment Share on other sites More sharing options...
robdyck Posted Saturday at 07:21 PM Share Posted Saturday at 07:21 PM Link to comment Share on other sites More sharing options...
Migaloo Posted Saturday at 08:54 PM Author Share Posted Saturday at 08:54 PM I am looking for some way to basically draw this using the foundation tools. Link to comment Share on other sites More sharing options...
Migaloo Posted Saturday at 09:48 PM Author Share Posted Saturday at 09:48 PM Where I am located we do a lot of slabs that are poured concrete footings with concrete block walls 2 to 6 blocks high, back filled with sand then a slab is poured over the fill sand flush with the blocks creating a modified monolithic style slab. This drawing is similar to that concept. Link to comment Share on other sites More sharing options...
SHCanada2 Posted Saturday at 10:39 PM Share Posted Saturday at 10:39 PM did you try creating a wall type that has the brick, and draw the foundation walls with that new wall type 1 Link to comment Share on other sites More sharing options...
Migaloo Posted Saturday at 11:02 PM Author Share Posted Saturday at 11:02 PM yes I tried that. If I could get the stem wall (whether concrete CMU's or solid filled) to show a brick veneer finish then that would work. I tried to play around with the brick ledge option but was not successful at that either. Its probably simple but I am overthinking it. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted Saturday at 11:59 PM Share Posted Saturday at 11:59 PM Just in case this can help... Link to comment Share on other sites More sharing options...
Migaloo Posted Monday at 05:09 PM Author Share Posted Monday at 05:09 PM Thank you for those tips. I will play around with it some more. 1 Link to comment Share on other sites More sharing options...
