FOOTING OPTIONS?
Migaloo
Where I am located we do a lot of slabs that are poured concrete footings with concrete block walls 2 to 6 blocks high, back filled with sand
then a slab is poured over the fill sand flush with the blocks creating a modified monolithic style slab. This drawing is similar to that concept.
yes I tried that. If I could get the stem wall (whether concrete CMU's or solid filled) to show a brick veneer finish then that would work.
I tried to play around with the brick ledge option but was not successful at that either. Its probably simple but I am overthinking it.
