Migaloo Posted January 25, 2025 Share Posted January 25, 2025 Is there a way to make concrete footings appear to be brick veneer in elevation views? Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 25, 2025 Share Posted January 25, 2025 below ground footings? I suppose one could change the material from concrete to brick. You may wish to post an image of what you are trying to do Link to comment Share on other sites More sharing options...
robdyck Posted January 25, 2025 Share Posted January 25, 2025 Link to comment Share on other sites More sharing options...
Migaloo Posted January 25, 2025 Author Share Posted January 25, 2025 I am looking for some way to basically draw this using the foundation tools. Link to comment Share on other sites More sharing options...
Migaloo Posted January 25, 2025 Author Share Posted January 25, 2025 Where I am located we do a lot of slabs that are poured concrete footings with concrete block walls 2 to 6 blocks high, back filled with sand then a slab is poured over the fill sand flush with the blocks creating a modified monolithic style slab. This drawing is similar to that concept. Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 25, 2025 Share Posted January 25, 2025 did you try creating a wall type that has the brick, and draw the foundation walls with that new wall type 1 Link to comment Share on other sites More sharing options...
Migaloo Posted January 25, 2025 Author Share Posted January 25, 2025 yes I tried that. If I could get the stem wall (whether concrete CMU's or solid filled) to show a brick veneer finish then that would work. I tried to play around with the brick ledge option but was not successful at that either. Its probably simple but I am overthinking it. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted January 25, 2025 Share Posted January 25, 2025 Just in case this can help... Link to comment Share on other sites More sharing options...
Migaloo Posted January 27, 2025 Author Share Posted January 27, 2025 Thank you for those tips. I will play around with it some more. 1 Link to comment Share on other sites More sharing options...
