mkennedy2000 Posted December 22 Share Posted December 22 That if you want to move a wall a distance "x" you can simply do the arithmetic in the dimension string text. Select the wall, select the dimension, type + or - "x" and it will move! Who knew.... 1 Link to comment Share on other sites More sharing options...
DBCooper Posted December 22 Share Posted December 22 You can also use simple math in most dialogs. So if you want something to be twice as big you can just type "*2" or half as big you can type "/2". Link to comment Share on other sites More sharing options...
mkennedy2000 Posted Monday at 02:41 AM Author Share Posted Monday at 02:41 AM Makes sense, good to know. Link to comment Share on other sites More sharing options...
Renerabbitt Posted Monday at 07:09 PM Share Posted Monday at 07:09 PM 16 hours ago, mkennedy2000 said: Makes sense, good to know. You can also type 4 in 12 for an angle Link to comment Share on other sites More sharing options...
mkennedy2000 Posted Monday at 07:29 PM Author Share Posted Monday at 07:29 PM Oh, nice. Thanks for the tip. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Monday at 11:03 PM Share Posted Monday at 11:03 PM You can also type in: 1 ft 1' 1 foot 1 in. 1" 1 inch 1 yd 1 yard 1 m 1 meter 1 hand (where "hand" is a custom unit) ...etc. The spaces aren't required and you can combine units (12' + 1cm would result in 144 25/64") and you can also enter angles with optional minutes/seconds (12 = 12°, 12 12 = 12.2°, and 12 12 12 = 12.203333°) and minute(')/second(")symbols are optional as well. FUN! For those not subscribed to Michael's Mailer, this is one of the types of hidden features/power tips I would normally only share there. Maybe consider signing up if you haven't already! 2 Link to comment Share on other sites More sharing options...
