Ringos Posted December 4, 2024 Share Posted December 4, 2024 In interior design elevation view, it would be nice to have a picture on the wall display. The photo frames in the library show in the elevation but not the picture in the frame. They display nice in ray trace. Anyone have good technique for this? Link to comment Share on other sites More sharing options...
basketballman Posted December 4, 2024 Share Posted December 4, 2024 Not sure what you are looking for ? Link to comment Share on other sites More sharing options...
Ringos Posted December 4, 2024 Author Share Posted December 4, 2024 Just now, basketballman said: Not sure what you are looking for ? That is a camera view, right? I was looking for an interior elevation view and how to get the art to show. Link to comment Share on other sites More sharing options...
basketballman Posted December 4, 2024 Share Posted December 4, 2024 Elevation view ... 1 Link to comment Share on other sites More sharing options...
basketballman Posted December 4, 2024 Share Posted December 4, 2024 " What is up with the downvote ??? " Have the courage to let me know ( privately, if necessary ) how my post is not relevant; how I might improve my answer ? Link to comment Share on other sites More sharing options...
GeneDavis Posted December 4, 2024 Share Posted December 4, 2024 I do wall art as a 3D solid and "paint" it (apply material) that is the image I want. These "pictures" won't display in Chief's 2D wall elevations, which default as vector views. Bob is showing you a standard view of a wall. Just change your view type from vector to standard. 1 Link to comment Share on other sites More sharing options...
robdyck Posted December 4, 2024 Share Posted December 4, 2024 31 minutes ago, basketballman said: Have the courage to let me know ( privately, if necessary ) how my post is not relevant; how I might improve my answer ? Hi Bob, it wasn't me, but obviously the reason somebody didn't like your response is because you demonstrated that you knew how to achieve the end result but you didn't describe HOW. The original question was clearly about how to accomplish it and required a description, which Gene provided. @RingosWhen using the 'Standard' rendering technique in elevation / section view, you can also turn on the 'Hand Drawn Lines on Top' and experiment with those settings to tweak the display to your liking. Link to comment Share on other sites More sharing options...
Solution Ringos Posted December 4, 2024 Author Solution Share Posted December 4, 2024 SOLUTION CA Support helped me with this. To show art in elevation views. Use standard view instead of vector view. Standard view might be a little dark but you can brighten up the scene using technique options. 1. Open the elevation. 2. Go to 3D> Rendering techniques> Standard view. 3. To brighten the scene go to technique options 3D> Rendering techniques> technique options. 4. Use a backdrop image to get great skys, use ambient lighting to get light in the scene, even put some hand drawn lines on it. 1 Link to comment Share on other sites More sharing options...
basketballman Posted December 4, 2024 Share Posted December 4, 2024 12 minutes ago, robdyck said: Hi Bob, it wasn't me, but obviously the reason somebody didn't like your response is because you demonstrated that you knew how to achieve the end result but you didn't describe HOW. The original question was clearly about how to accomplish it and required a description, which Gene provided. @RingosWhen using the 'Standard' rendering technique in elevation / section view, you can also turn on the 'Hand Drawn Lines on Top' and experiment with those settings to tweak the display to your liking. " Gotcha ; thought it was obvious .. Link to comment Share on other sites More sharing options...
