TawharauNZ Posted November 21 Share Posted November 21 I have just upgraded Chief from x12 to x16. I still have x9, x11 & x12 on my computer. Am i ok to delete those old versions? Tryna make space on my computer if i can. Thanks Link to comment Share on other sites More sharing options...
ericepv Posted November 21 Share Posted November 21 You can delete them. As long as you are current with your SSA, you can always download the older versions from the Chief website. Check your Digital Locker for a list of which versions your license is good for. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted November 22 Share Posted November 22 Personally, I would probably keep X12 installed just in case you need to make some changes to an old plan and don't want to bring it forward into X16. Once you save a plan in X16, you won't be able to open it up in X12 and if you let your subscription run out, then you won't be able to open it at all. Link to comment Share on other sites More sharing options...
Roxi0112 Posted December 11 Share Posted December 11 why is that DBCooper that you wont be able to open up the file at all? Link to comment Share on other sites More sharing options...
Smn842 Posted December 11 Share Posted December 11 47 minutes ago, Roxi0112 said: why is that DBCooper that you wont be able to open up the file at all? As the OP has just upgraded to X16 it’s on the subscription model with no perpetual fallback. Hence if the subscription is ever stopped and the plan is in X16 format it cannot be opened in X12 which the OP does have a perpetual license to. Link to comment Share on other sites More sharing options...
