importing
decorators3
HI
I am trying to import this siding material the clients wants to see to put on their house . I an import no problem but  how can I  size it properly - when I  use the define material TEXTURE to adjust it just ends up all over the house not as actual  siding
1 hour ago, DavidJPotter said:
You need an image of several pieces of siding to use as a custom material, not just one piece to get the effect you want or make one.
thank you David.. it worked.  I knew I had done it before but I couldn't figure it out..
7 hours ago, GeneDavis said:
Are you wanting a textured clapboard siding material?  Surface as seen with James Hardie "Cedarmill" or LP Smartside?
If so you'll need a seamless image of lapping boards.
Show us how your solution looks.
ok will do thanks!
