JKEdmo Posted Tuesday at 06:04 PM Share Posted Tuesday at 06:04 PM Good morning, I brought a model forward from X15 to X16 (attached). Since then the model has become really slow and sluggish with a lot of "rebuild 3d model" events. I don't think the model is especially large. Was wondering what people do to troubleshoot something like this. For example, how to find and purge a large complex symbol that might be causing problems? Lastly, in Autocad there is a command (Audit) used to fix and repair files. Does Chief have anything equivalent to fix "broken" PLAN files if that's even a thing? Thanks once again, Jim PARKES - PROPOSED.zip Link to comment Share on other sites More sharing options...
JKEdmo Posted Tuesday at 06:55 PM Author Share Posted Tuesday at 06:55 PM Update: I submitted the model file to tech support. (I keep forgetting I pay for this resource!) We'll see if Chief has any good advice. Jim Link to comment Share on other sites More sharing options...
Renerabbitt Posted Tuesday at 07:11 PM Share Posted Tuesday at 07:11 PM Just now, JKEdmo said: Update: I submitted the model file to tech support. (I keep forgetting I pay for this resource!) We'll see if Chief has any good advice. Jim Its the two roof planes you have cutting into the fireplace 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted Tuesday at 07:26 PM Share Posted Tuesday at 07:26 PM I agree with Rene, but don't understand why those would cause such a slow render. It's slow on mine. What is the workaround? Do the fireplace all in solids? Link to comment Share on other sites More sharing options...
Solution BrianBeck Posted Tuesday at 07:27 PM Solution Share Posted Tuesday at 07:27 PM Quote Its the two roof planes you have cutting into the fireplace It's actually because Auto Roof Returns are turned on for the walls in the Fireplace, as well as a bunch of other walls in the plan where it probably doesn't need to be on. The fireplace walls are the ones causing the slowness though. If you select them and turn off Auto Roof Returns the plan is no longer slow to build 3D. Link to comment Share on other sites More sharing options...
Renerabbitt Posted Tuesday at 07:35 PM Share Posted Tuesday at 07:35 PM 8 minutes ago, BrianBeck said: It's actually because Auto Roof Returns are turned on for the walls in the Fireplace, as well as a bunch of other walls in the plan where it probably doesn't need to be on. The fireplace walls are the ones causing the slowness though. If you select them and turn off Auto Roof Returns the plan is no longer slow to build 3D. nice, thanks for the info Brian Link to comment Share on other sites More sharing options...
JKEdmo Posted Tuesday at 07:36 PM Author Share Posted Tuesday at 07:36 PM Thanks for all the help. Working on cleaning this up right now. I'm curious for my own education -- how did you all zero in on the problem area so quickly? Link to comment Share on other sites More sharing options...
JKEdmo Posted Tuesday at 07:45 PM Author Share Posted Tuesday at 07:45 PM Thanks all! I got it fixed and learned a bit more. I was certain it was the X15 --> X16 upgrade, but that was a red herring. Goes to show not to jump to conclusions. Jim 2 Link to comment Share on other sites More sharing options...
Renerabbitt Posted Tuesday at 08:55 PM Share Posted Tuesday at 08:55 PM 1 hour ago, JKEdmo said: Thanks for all the help. Working on cleaning this up right now. I'm curious for my own education -- how did you all zero in on the problem area so quickly? Just had a look at the model and to me it was either solids, walls, or roofs, so i used the layer hider until the model sped up Link to comment Share on other sites More sharing options...
JKEdmo Posted Tuesday at 09:00 PM Author Share Posted Tuesday at 09:00 PM 3 minutes ago, Renerabbitt said: i used the layer hider Thanks Rene' -- I'll look into this tool. Jim Link to comment Share on other sites More sharing options...
