JKEdmo Posted October 22, 2024 Share Posted October 22, 2024 Good morning, I brought a model forward from X15 to X16 (attached). Since then the model has become really slow and sluggish with a lot of "rebuild 3d model" events. I don't think the model is especially large. Was wondering what people do to troubleshoot something like this. For example, how to find and purge a large complex symbol that might be causing problems? Lastly, in Autocad there is a command (Audit) used to fix and repair files. Does Chief have anything equivalent to fix "broken" PLAN files if that's even a thing? Thanks once again, Jim PARKES - PROPOSED.zipFetching info... Link to comment Share on other sites More sharing options...
JKEdmo Posted October 22, 2024 Author Share Posted October 22, 2024 Update: I submitted the model file to tech support. (I keep forgetting I pay for this resource!) We'll see if Chief has any good advice. Jim Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 22, 2024 Share Posted October 22, 2024 On 10/22/2024 at 6:55 PM, JKEdmo said: Update: I submitted the model file to tech support. (I keep forgetting I pay for this resource!) We'll see if Chief has any good advice. Jim Expand Its the two roof planes you have cutting into the fireplace 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted October 22, 2024 Share Posted October 22, 2024 I agree with Rene, but don't understand why those would cause such a slow render. It's slow on mine. What is the workaround? Do the fireplace all in solids? Link to comment Share on other sites More sharing options...
Solution BrianBeck Posted October 22, 2024 Solution Share Posted October 22, 2024 Quote Its the two roof planes you have cutting into the fireplace Expand It's actually because Auto Roof Returns are turned on for the walls in the Fireplace, as well as a bunch of other walls in the plan where it probably doesn't need to be on. The fireplace walls are the ones causing the slowness though. If you select them and turn off Auto Roof Returns the plan is no longer slow to build 3D. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 22, 2024 Share Posted October 22, 2024 On 10/22/2024 at 7:27 PM, BrianBeck said: It's actually because Auto Roof Returns are turned on for the walls in the Fireplace, as well as a bunch of other walls in the plan where it probably doesn't need to be on. The fireplace walls are the ones causing the slowness though. If you select them and turn off Auto Roof Returns the plan is no longer slow to build 3D. Expand nice, thanks for the info Brian Link to comment Share on other sites More sharing options...
JKEdmo Posted October 22, 2024 Author Share Posted October 22, 2024 Thanks for all the help. Working on cleaning this up right now. I'm curious for my own education -- how did you all zero in on the problem area so quickly? Link to comment Share on other sites More sharing options...
JKEdmo Posted October 22, 2024 Author Share Posted October 22, 2024 Thanks all! I got it fixed and learned a bit more. I was certain it was the X15 --> X16 upgrade, but that was a red herring. Goes to show not to jump to conclusions. Jim 2 Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 22, 2024 Share Posted October 22, 2024 On 10/22/2024 at 7:36 PM, JKEdmo said: Thanks for all the help. Working on cleaning this up right now. I'm curious for my own education -- how did you all zero in on the problem area so quickly? Expand Just had a look at the model and to me it was either solids, walls, or roofs, so i used the layer hider until the model sped up Link to comment Share on other sites More sharing options...
JKEdmo Posted October 22, 2024 Author Share Posted October 22, 2024 On 10/22/2024 at 8:55 PM, Renerabbitt said: i used the layer hider Expand Thanks Rene' -- I'll look into this tool. Jim Link to comment Share on other sites More sharing options...
